Warm idle problem
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I notice when the car first turns on, after a few cranks that is, and it's cold from not driving in awhile it idle for the most part, but once it warms up if I let off the gass completely or shift gears too long it'll dip way to in the revs and then die. Ideas why it would not hold idle when warm?
eric
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
i would guess a combination of problems. if you had a bad oxygen sensor it could cause your engine to idle high when cold. if you also had a boost leak, the idle would be too low. that would cause this exact phenomenon
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
on my other car, a bad oxygen sensor caused my idle to bee to high at cold because it was misreading the oxygen content/temperature of the engine... so it couldnt compensate for it being cold... if you had a boost/vacum leak along with that, it may drop the idle back to where it should be when its cold... but when its warm the vac leak will shine through,
