Walbro Install now Running lean?
Justin
Speakers?
Spokane, Wa
I'm running about 11 PSI on stock turbo, stock fuel, VPC, E01 and an LC1 wideband. When I would hit full boost I'd run about 10.3 +\-
I just installed the walbro 255, now I'm running low 11's!!! my idle has also gone down, I've always had a really shitty idle, way high (1000RPMs+) and after the install i have had an 800 rpm idle more frequently... the car seems more smooth over all....
any idea why I would go lean after a higher flow pump?
would the idle thing be related, or just a sign of a kinda shity old pump?
Justin
Speakers?
Spokane, Wa
IJ. said:
J tube restriction still in place?
12v modded?
Yes, and No.... I spaced the 'j' tube. havn't done the 12v mod yet, I am going to do it so I can pull the resistor and relay so I needed to do some reading.
Bishop, Yes.
Bishop92t
773
USA
www.ma70.com
Possibly overloading the stock FPR or having J-tube problems. Without a fuel pressure guage it'll be hard to diagnose accurately.
dbsupra90
toonar
indiucky
i would think if it is a restriction with the fpr or j tube it would cause an increase in fuel pressure which should make it run richer no? thats why i had thought perhaps it was something on the feed side causing the restriction.
but like you said, without a fp gauge its just a guess.
Doward
4,245
Alachua, FL
Maybe fuel filter? I know it's supposed to be a million-mile job, but if some piece of trash got lodged, who knows what would happen with extra pressure behind it?
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
This is strange, there is probably some form of restriction before the injectors cause any restriction after like the FPR and the J-tube will cause a high pressure and therefore more fuel, not less.
cjsupra90
Jun 11, 2005
1,029
Lakeland, FL
Millon-mile job?:icon_surp
The fuel filter should be changed once a year or every 12,000 to 15,000 miles.
Justin
Speakers?
Spokane, Wa
Not really, but lets keep that debate out of my thread... I've read alot of arguements between wether it needs to be changed or not...
