W58 on 7M-GTE help
jrfn354
the Toy is boss
Apr 20, 2009
11
Madison, AL
Okay guys, here's the deal. I'm mating a W58 to my GTE, but with an R154 clutch kit. The W58 throw out bearing collar is too small to accept the R154 bearing. Will a R154 collar fit snuggly on the W58 input shaft or am I looking at buying a new damn tranny?
jdub
Feb 10, 2006
10,730
Valley of the Sun
What could possibily make you think a R154 clutch would fit on a W58?
(Why not just use a W58 clutch?)
primercrx
59
Lexington, South Carolina
I just finished up mating my w58 to my gte, but I used a w58 clutch kit. The pressure plate, flywheel, and release bearing are different for the r154 and w58. The clutch discs can both interchange b/c the shafts on both are both 21 spline. In order to correct your problem, you will need the proper parts. (flywheel, pressure plate, release bearing) Hope this helps.
mista_sup
211
atlanta
do you guys think it will last?? and if so with what clutch???
x87SUPRA87x;1307241 said:
The w-58 is a push type, the r154 is a pull there is no way you will get that to work. There are performance clutches for the w-58 out there you just have to look around.
JesseH
1,153
Englewood, Ohio, United States
I've been running 350-400HP on my w-58 for awhile, It was a fresh tranny and I put in a custom stage 3 6-puck dual spring feramic with a stock pressure plate, I out powered the pressure plate and then went up to a 2800lb cluchmasters and haven't had a problem.
As for how long it will last depends on how you drive, If you beat the hell out of it making decent power don't expect a long time. I have fun with mine but I also take care of it too. Heavy launches will end you pretty quick.
jrfn354
the Toy is boss
Apr 20, 2009
11
Madison, AL
Okay, it's all fixed now. The guy I bought it from had those parts, so I was seeing if it was possible with that setup. Obviously, it's not, so I'm putting out the cash for an r154. I plan on building up the engine soon anyway. As a result, I'm selling the W58. Thanks for the help.
