VSV needed to operate the heater?
rakkasan
Currahee!!
Fort Campbell, KY
If I remove my A/C, I should be able to use the heat if I remove (or bypass) the VSV too, correct?
Edited due to piss poor grammer :nono:
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
The VSV craps out. That they do. Mine did. Just hook the vacuum line straight to the heater water valve in the winter and then remove it and stick a golf tee into the hose in the summer.:biglaugh:
If you ever go to some mtns in the summer, you can just plug it into the valve for the cold nites.:biglaugh:
