ok, stupid question time fellas.....
so what is a vsv, where exactly is it, and can i bypass it/remove it?
7MGTEJoe said:Why would you want to remove/bypass a part if you don't know what it does?
GrimJack said:1
You can run without the first one, as long as you don't mind always running hot coolant in the cabin.
You can pull the second one if you remove the EGR system. You can only get away with this in areas with no smog checks, of course, and IMO it removes valuable functionality from the engine.
The only way to remove the last one that I am aware of is by getting an aftermarket fuel system, including an adjustable FPR.
boost fiend said:water injection systems my friends.
boost fiend said:well the heater core has been bypassed, i have no egr system, and i read about the vsv around the fpr and just wanted to see it it would be a huge issue if i removed it. thats all. but thanks for the help and the worry about removing them.
:biglaugh:boost fiend said:ok, stupid question time fellas.....
boost fiend said:thats all i needed to know. i have a good idea what goes on under the hood. as this being my first turbo car of this kind its just a few thoughts. some people help, some dont. you build one way, ill build my way.
No, I think you have the right idea about asking.boost fiend said:im used to building carb-based chevys. 500-600whp is diffrent there. turbos are new to me. is it a bad thing to ask for a lil help before i just start ripping things out? i like carbs vs. efi anyday.
