VSS source question
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
Hey guys im going to be wiring up my megasquirt soon and it accepts a VSS sensor input. I was wondering which one i should use. I know that their is a sensor that is in the combo meter that is run from the speedometer cable or i could use the ABS sensor in the rear of the r154. Which would be best to use or does it matter? Thanks
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
well it does some things like speed based boost control and flat shift and gear indicator as well as logs speed.
