Ok, My engine is the Pre 89 and all the Diagrams Ive seen for the 89+ models. Is there anyone out there that can Point me in the Correct Direction to find out the Wiring for the Pre 89s
ok here we go...u'll hafta follow the vpc harness wires into the correct pin of ecu.
This should be helpful also... http://www.apexi-usa.com/pdfWiring/1.pdf
just look for our diagram, follow the pins to the wires and spliced, this attachment also helped a bunch, hope it helps you also.
