I have it installed and Its running but for the Life of me, I can not get this thing to give me the correct A/F readings. At Idle and Everything set to 12 oclock on the VPC MY Air fuel readings on my Wideband are 10.3 to 10.5
Now I take the Idle Knob on the VPC and turn it to -14 which is the most that you can turn it too for lean Purposes Im reading 11.4 to 11.6
Turn the SAFC to -24 to try and lean everything out and at that setting, Its only reading 13.1 anything lower than that it starts to bog down. Problem with this is that I have no Acceloration. If I tap the throttle, It bogs and If I get through the Bogging out, I can hold it at 2400RPM range and the A/F level drops to 10.3
What the heck is going on here. Can someone Please tell me what Im doing wrong. I need to get this thing out and running on the road my Monday. Any Advice, Please call my cell at 505-442-9793
Robert
Robert
