Basically, I pressure washed the engine and I got the alternator soaked and I think the voltage regulator pooped the bed LOL You wana hear somethin funny? after about 14.5 volts the ABS stops working? wierd huh? and the temp guage goes way up. Okay ill get to the point, the voltage is too high and I need to know if the regulator is located in the ALT or not so I can replace it. It depends on the vehicle if its built into the ATL or not. I think the water fried somethin and when I go above 2 grand the voltage gets too high and screws up the sensors and stuff.
