voltage drop from battery to ecu
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
hey ya'll..
just got the fcon installed and was checking to see if it powered up and i measured the battery and have about 12.6v
when i checked the power @ the fcon i only have about 9.8v
is this voltage drop normal? if not... what could be causing it?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I don't think so... I checked my power levels at the ECU when I was installing my wideband a while back, I was definitely in the double digits.
Anything else still on in the car? Stereo, lights, rear window defogger?
tissimo
Stock is boring :(
Melbourne, FL
you have an fcon jumper harness? check the pins on them and make sure they are snug.. I'm actually have same sort of problem.. but i have 14 v (when running) and 12.7 at the ecu.. when i get on it it drops to 11.8... I havn't looked but maybe my 1jz-2jz jumper harness is loose.. or maybe the wire is to small?
edit: just read you checked at the harness? so means its somewhere else? does the power come from the fuse box (i dont have the diagram in front of me).. maybe a little corrotion on the pins in the connector..
