Hey guys and gals, I recently installed a 5701 Viper alarm/remote start in my '90 N/A. I posted this @ the12volt.com, but figured I'd tap into the brain power here and see if anyone could help.
It works just fine 9/10 times, BUT sometimes the remote start acts up.
The system has a "Manual transmission Mode" that MUST be set EVERY time you exit the car in order to allow the remote start to function. While setting this MTM, I run into a repeating problem every 5th try or so.
This is what is supposed to happen:
While car is running, press brake pedal
now engage E-Brake
Release brake pedal
press remote start on remote (remote plays tones, lights flash)
remove keys, exit vehicle
Arm vehicle (Car shuts off, arms itself and remote plays different tones notifying you remote start is ready)
Here is exactly what happens when mine goes weird:
I hit the foot brake
Pull ebrake
release foot brake
press remote start on the remote
car flashes lights, remote plays ascending tones, all is well
get out and close door
ARM CAR ----car chirps once as the car shuts off, but does NOT arm the factory alarm and the car turns right back on 2-3 seconds later. I can turn it off with the remote by pressing the remote start, but it will turn on yet again.
The second time it tries to start the starter engages for waaaaaayyy to long. About 2 full seconds.
The strange part is that this does not happen normally, but it has happened at least 5 times since I installed it last week.
Settings:
Manual tranny turned on,
Tach reading set to Tach
All other remote start options are factory settings
Now another bad thing that happened today:
I parked it without doing the manual tranny mode shutdown.
When I went to unlock the car it tried to START!!! I left it first gear with the ebrake on. It didn't really go anywhere, but it kept trying to start and lurching forward.
It acts perfectly normal and everything functions most the time, but these strange issues are making me think the unit might be bad or something. Could this be due to a faulty wiring connection in the car?
If I can't figure it out, I may send the brain back to Directed. I bought the unit for the security, the remote start is more of a luxury/toy than anything so I could just turn it off, but it has a built in turbo timer which would come in handy when I do my turbo swap.
Thanks for reading and I would greatly appreciate any input from those more knowledgeable than myself.
-Andy
now engage E-Brake
Release brake pedal
Pull ebrake
release foot brake
Settings:
-Andy
