madsupra88 said:LMAO at the end..
Did they let you do 4th gear pulls? I dont like above ground dynos because the one I went to only would do 3rd gear pulls, uh, for safety reasons... :dunno:MK3Brent said:
Power band is quite usable.
This particular dyno was an above ground dyno, with one roller half the size of the in ground dyno-jets. I wasn't building boost nearly as fast.
For example: boost controller set for 20psi would hit 20psi at 4500 on the street, however will hit 16psi at 4500 on the dyno, then creep to 20 by redline.
I'm lifting the head.Reign_Maker said:Did they let you do 4th gear pulls? I dont like above ground dynos because the one I went to only would do 3rd gear pulls, uh, for safety reasons... :dunno:
Love the vid, Tamara and I LOL'd at the end... Did you really get BHG?
Thanks, that means alot to me.AGlobalThreat said:Looks and sounds great I want to see more!![]()
