I'm looking to do the headgasket on my 7mgte. I am looking at a victor Reinz Nitroseal headgasket from rockauto. https://www.rockauto.com/catalog/moreinfo.php?pk=2654710&cc=1278468&jnid=479&jpid=5
Stays cool at temperatures up to 1,800° F
• Doesn't know how to relax... no re-torque required
• Maximum heat transfer keeps your head (& manifold) straight
• Coolant, fuel and oil... no problem
• Designed to seal minor surface irregularities
I do not have the funds to bring my entire block to the machine shop to have the deck blocked, nor the money to do a bottom end rebuild. I will not be pushing much more than stock boost and I will not be bringing it past fuel cut for sure. I have a pair of used ARP headbolts that I received in a trade that I am looking to use with it. I'm just looking to get the car up and running as a daily. I will get the head machined if it is out of spec from TSRM.
Is this headgasket gonna blow on me after a few thousand miles or will it last about oem time? Any reviews for this headgasket in particular?
I would be re-sealing the rest of the engine via TSRM and whatever gaskets come in the Mishumoto ebay kit.
