very bad and weird tranny problems. need help quick!
89Turbo
804
Portland
so from a stop, i accelerate normally and it shifts from 1st to second perfect, but then it stays in second and will not go into third no matter what, i was doing 50mph on the freeway running at 5grand, it was rediculous. And when i totally let off of the gas doing 50 it goes all the way down to 600rpm(idle speed) and from a roll i have NO powerband from idle to 3500. Now im thinking that it has something to do with the 2nd-3rd shift solenoid or someone else suggested that it could be a major vacuum leak, so im going to see a tranny shop on Thursday which is my first day off and need some suggestions of what this might be before they look at it.
BTW- fluid level is perfect, mods are in sig, OD button on or off doesnt matter still does it.
89Turbo
804
Portland
johnathan1 said:
Why does it say "poorly built A340E"?? Maybe that's your problem? :biglaugh:
well yeah it is and im taking it back to the guy to get fixed, but that was a rev limiter problem in the 1st-2nd shift.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
Unplug the solenoids or the ECT ecu, and shift L-2-D, if you get third in D, its an electrical (solenoid/ecu) issue. If you dont , its mechanical, time for trans overhaul.
89Turbo
804
Portland
ECT ECU is....under the dash?
jdub
Feb 10, 2006
10,730
Valley of the Sun
He nailed it...it's called a manual shift test in the TRSM. My ECT ECU failed and I was getting all kind of shift weirdness...unplugged it and was able to get around till I figured it out. With the ETC unplugged, you are the ECU ;)
And it is behind the passenger side kick panel.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Nah...won't mess it up. Takes some getting used to though having to shift an auto manually. Keep the rpm down in L1 and L2.
It has one connector, the label has "7M-GTE" in big letters and "ECT" in smaller letters at the lot of the label.
JesseH
1,153
Englewood, Ohio, United States
So would this affect shift points correct? because when I WOT it will haul, and then other times it seems like its missing a gear. would this be my problem or would it be the kickdown cable?
jdub
Feb 10, 2006
10,730
Valley of the Sun
The ECT controls the shift points. The throttle postion cable (kick down) controls line pressure...it affects how smooth the shift is.
JesseH
1,153
glad you told me that one, I was about to drop the tranny to change the kickdown cable. saved me alot of work. I guess now I need to look for a ECT ECU. know anyone whos got one?
89Turbo
804
Portland
just verifying, so if this doesnt work and it wont go into third, then it is mechanical and im screwed? and overdrive is still not going to work eiter since it is electronically controlled right? and if it does work then potentially all i need to change is the ECT?
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
Ya, you got it. Usually when they start to go , you will notice a delayed shift that keeps getting worse, maybe shudders when shifting, maybe you have to back off throttle a little then it shifts. Those are the normal symptoms I've seen.
jdub
Feb 10, 2006
10,730
Valley of the Sun
If it won't shift with the ETC unplugged doing it manually, yes it's mechanical. The overdrive should work shifting manually. Take a look at the TRSM for more info.
89Turbo
804
Portland
man this is hopefully gunna save me some major $$$, anyone have one they can sell me?
thanks everyone, i like to think i know quite a bit about the Supra, that is until i get on here and it makes me look dumb, lol oh well. i'll keep this updated im gunna try it when i get home.
89Turbo
804
Portland
tookwik4u89 said:
So, is 3rd working now with ecu unplugged?? If so, you now need to figure out if its ecu or solenoid.
im at work i havent done it yet, it will be about 10-11pm tonight before i know
