Venting Greddy RS
viperjames
22
Brandon
i have an 89T and its basically stock with hardpipes and BOV and im running the greddy type S and as most know venting creates richness and stalls when i come to a light or stop. i have played with it and cant seem to get it right.
my question is with the SAFC if i get one of those what controls do i adjust to fix the idle and between shifts.?
also if i get the greddy RS do you think it would be better to vent to the atmosphere or would i be in the same boat? anyone run this?
i have searched!!
mazzer
438
st.louis,mo
mine used to do it all the time. but since i did my HG and had the bat discon. it hasnt really done it since i re-learned..sometimes itll dip down into the 3-500rpm range but never dies anymore
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
if u get the MAFT you can run it in blow through and as long as the BOV is before the MAF it wont dip down like that, im running my type S pretty much off my chargepipe
GotBoost?
I do
Nov 25, 2005
318
By My Computer
The richness is tuned out if you play with it long enough. I don't know if you have the option (since you have hardpipes), but I started running the stock bov and the Greddy type s at the same time, and then it ran perfect, no problems at all.
turbomk3
i use the type s on my hardpipe kit and used to have the rs and neither of them ever made me die. It would sometimes dip into low rpm's but never die. i remember on my rs i went on the soft setting rather than hard.
dbsupra90
toonar
indiucky
the bov function (dec air) on the afc does not work w/ our cars since we use kv.
if it is tuned right it will reduce the likelyhood of the stalling.
