Valve to piston clearance
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Hey guys,
I’m getting ready to check my valve to piston clearance and just wondering if any of you guys ran into a problem of not having enough clearance? My block had 0.010 milled of which put my pistons 0.010 above deck, and my head had around 0.040 milled off to get a clean surface to run a MLS gasket , also my new cam is a 9.2 mm . I was planning on running a 1.4 mm gasket to get 8.8 CR that I was shooting for. My pistons are wisco with valve relief also what is the recommended clearance ? :1zhelp: . thanks
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Doward;882796 said:
There's not so much a 'recommended' clearance, as a minimum clearance. Clay it and see what you get :)
im not going to have time to do it until next week, do you think ill run into a problem with the lift on the cam and milling ? ohh i run stock valves
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Okay, so you've got 0.050 milled off (1.27mm) and are compensating for that with a 0.2mm increase in gasket thickness... That still takes more than 1mm from your clearance. Add in increased cam lift and I can about guarantee that you are now running an interference engine. Take good care of that timing belt, 'cause if it goes, you've got an engine rebuild on your hands.
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
i know thats a total of 2.7 mm in clearence loss, i'm getting mixed answers :aigo:
bfr1992t
The quiet one
Oct 29, 2005
272
Ohio
Too many variables for our ESP (Extra Supra Perception) abilities to tell, clay it. Don't forgot to put a HG between the block and head when you do.
