Valve Tick (Need new shims?)
JDMMA70
2,550
Houston
I recently got my head machined and had new valve stem seals put in the motor. During the initial start up you could hear this very audiable ticking noise. So I wanted to ask if this was normal on a rebuilt head, the man said it would go away after a few hundred miles, but I looked around and now I wanted to ask what you guys think the problem may be?
The ticking is audiable throughout the RPM Range
It sounds like a sewing machine its annoying and I want to get it fixed asap
Thanks
~JDMMA70
omfgitsdonovan
Laag master
Jul 23, 2008
99
Burlington,WA
I have the same problem with my car after i replaced my headgasket for me the ticking sound is coming from a few vavles that are loose so all i have to o is today im going in and measuring the clearances and putting in new shims for the buckets, then my problem shoud be solved.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Make sure your cam saddles are torqued to spec, if their not that'll make a ton of noise. Other than that there aren't any shortcuts, you have to measure the clearances, do the math and install new shims where needed.
