valve stem seal replacement? =(
rodama5anthony
430
Bay Area, CA
so i need to do replace my valve stem seals so i wanted to know if any you guys had any trick, tip, or suggestions. also if any of you know of a "how to" thread that would help alot.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I did my own... then I had a stuck intake valve... ruined the head. I'll always wonder if I caused it. Id get the correct spring compressor, not the redneck fix I did with the PVC pipes.
Sent from my HERO200 using Tapatalk
rodama5anthony
430
Bay Area, CA
lol will do captain
---------- Post added at 07:13 PM ---------- Previous post was at 07:01 PM ----------
seoul4korea;1645989 said:
thanks man this is a big help!
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
I've tried redneck style and it is way more work than it's worth IMHO. I did two valves that way and it was taking longer than it would have to remove and replace the head. Unless the cost of the HG is an issue I would just do it the right way.
rodama5anthony
430
Bay Area, CA
alright thanks guys for all your help. im going to be replacing it wit the engine still in the car, after reading all your explanations i have a few questions:
how do i know when the piston is at TDC?
is there a specific sequence that i need to change them in?
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
There is no specific sequence.
TDC (Top Dead Center) is when the piston is at the top of it's stroke. You'll want to look down in the spark plug hole with a flash light to see where the piston is. Then rotate the crank by hand until the piston is at the top. Then put a wooden dowel in the spark plug hole and rotate the crank while watching the dowel. Once the dowel stops rising, you're at TDC.
Removing all of the spark plugs makes to rotating part easy.
Make sure you use the little plastic sleeve that comes with the valve stem seals. It slides over the top of the valve so the seal won't get damage when you slide it down the valve stem.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Make sure the valve keepers don't fall into the cylinder! lol that would suck.
I will be doing this soon on my 1JZ, I'll take pics.
What fitting did you use to put the air in the cyl Kenny?
Good info, I like the pvc tool too! haha
Sam
CajunKenny
Nov 15, 2007
3,255
Washington
^That would suck!
I used the hose in my Compression Tester Kit. It threads in to the spark plug hole and just so happened to have the right air fitting. Yeah, the PVC tool was kind of ghetto; but, it worked. ;)
rodama5anthony
430
Bay Area, CA
thanks for the info guys. i have a air compressor so ill be using that to keep the valves from falling in the cylinder and ill be sure to have a magnet handy to get the keepers after i compress the springs
