Ok gang, I have read ONCE, and ONLY ONCE but have never seen the definant truth.
I have 272 degree, 8mm lift cams be made as we speak. A while back I read that the stock shims ( or stock thickness range) was on the "brink" if you will with an 8mm lift.
Stock being 7.4mm lift roughly.
Here on this website:
http://www.billzilla.org/4agmods.htm
This is judging by the way he worded it, the larger diameter shim under bucket design with a cam lift of GREATER than 8mm MAY cause this phenomenon. Though I have never personally heard of this or seen this until now, have any of you experianced it with an upgraded cam set?
This is coming from 4age tech. Roughly the exact same valve system set up as the same dated 7m series.
Though when he is talking of this phenomenon its usually dealing with HIGH REVVING motors. But since the 7m (pre-89 ecu) rev cuts at 6800 rpm, I doubt this could happen. I only see this happening on a HIGH revving motor.
I am having a hard time sourcing out a shop that could make me some shim UNDER buckets...
I know Defiant7m has them from the 1sz-fe 1 liter 4 cylinder from japan, but I cant seem to get him to answer a simple question as to HOW he aquired them.
Any help or advice is welcome. Either way I will try this set up on the stock shim over buckets with my comp cam valve springs, stock retainers, Ferrera valve locks.
Should be a good strong set up for 500 crank hp.
-Jonathan
low 300's and roughly 8mm lift, the 'shim over' buckets will occasionally catch the edge of the shim with the top of the lobe of the cam and spit it out the side, thus RAPIDLY destroying the bucket and most likely a fair chunk of head in the next few milliseconds.
-Jonathan
