this might be a better spot for this then in general
Valve Job 6 cyl recessed springs: $xx
What the valve job consists of is: hot tanking, valves removed, carbon cleaned, cut seats/valves, clean and check springs/guides, check for cracks, pressure test, install new valve seals.
If you don't do the entire valve job, installing the valve seals alone will be $xx
maybe some imput on this is what im looking for, im doing a mild build looking for 300whp and then later 350-370 whp
is all that needed? should it be done? what should i know saying yes or no to this
