valve cover gaskets!
code14
USA
hi all!
i just replaced the gaskets on the valve covers and uhh... i remember reading somethin about people replacing the valve cover bolts with something else?? i might just be crazy...
well, if anyone could shine some light on this for me... i'd be much obliged :D
thanks in advance!
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
code14 said:
hi all!
thanks in advance!
yeah we replace them with hex bolts. PM Stretch, he can hook you up with some canadian bolts :D
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Yep. Get rid of the screws with the stupid little grommets, and put some real bolts on there. 6mm X 25mm IIRC.... and lock washers.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
the reason they are just phillips screws is cuz they only need enough torque that you can tighten with your hand(i dont remember the number)..cuz i guess overtighting them would be really easy if they gave you the chance to use a socket wrench..and that would squish the gasket making that oil leak.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
I think it was 24 IN./pounds.
I just reused the screws, no sense in getting a socket on there for 20-something inch pounds.
