vacuum/vsv question
hornet7288
260
Savannah, GA
I am doing the last few touches on my gte before we swap it in today. I got one of the vsv's hooked up, but my question is about the other one. It's the one that sits about the vacuum tank on the n/a. My hard line that the vsv's get the vacuum from only has one nipple like the setup on the n/a for the first vsv as seen here:
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=1708&P=2
It comes off of the hard line --> to the vacuum pump-->vsv-->ACIS.
Here is a diagram of the turbo setup
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=1708&P=3
Should I just tap into another vacuum line using a t-fitting? If so, which one? Thanks
