Hello
After the cold start systems is done with my car still idles high. it is usually somewhere in between 900rpm and 1100rpm...most sitting at 1000. Checking the TSRM, it didn't mention anything about a vacuum leak so i want to start of with this.
i have no codes
i did notice a vacuum hose however that was lose...a small one. it is the bigger of the three metal pipes that come from the front of the intake manifold and it splits off right around the front knock sensor. i couldn't see where it would go. Where does it go?
Thanks
i have no codes
Thanks
