Vacuum leak
1SLOMK3
218
Arizona
My fuel pressure regulator is loose, you can move it back and forth. Could that be where my vacuum leak is? It sounds like it is in that area. I sprayed some soapy water on it and it changed the idle for a second. Is it normal for the regulator to move if you turn it?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
No it shouldn't be loose, the diaphragm cap should be crimped on there tight (I think its crimped). Pretty sure I have a stock regulator you can have for free, where in AZ are you?
