alright i came across this while trying to hook up my boost gauge cuz my stock one doesn't work.
i tapped into the vac line that goes to the stock turbo pressure sending unit and absolutely nothing happened...no vac and no boost showing. so i sat there and scratched my head.
i unplugged the boost gauge, blew into it and it the needle creeps up a bit and when i sucked on it it moved into the vac section so i know the gauge is working. and you can see from the first picture that it's plumped into the correct line.
at this point i'm suspecting a leak from somewhere so this is where i need help.
i don't know how ti check for a vac leak. please help.
also, could someone help me identify the things in the following 2 pics that i pointed to.
thanks
thanks
