vacum leak? Charcoal Canister ??
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
Just tried to put my Charcoal Canister back in and blamo, vacuum leak, The vacuum line was fine but it being connected to the canister was causing the leak,
i am obviously missing something here? what is it?
As soon as i disconnected the CC and put that Vac line back the Vac leak was gone and i was getting vac again in the Mani.
bobiseverywhere
bobb'n for money
Montreal
no stand alone stock ECU, Didn't see a hole in the CC and it is my HKS electronic boost gauge that shows the no vaccum when i have the CC connected,
I did have it T'ed from the Same Vac Line, if that matters? I changed those lines around a bit so i don't remember exatly what vac line was for the CC, i have them all used currently so???? i'm not to sure
Ninja Edit Stock ECU
bobiseverywhere
bobb'n for money
Montreal
annoyingrob said:
no vacuum? I don't think thats the CC. It's a small line going to the CC, there's no way it would cause you to lose ALL vacuum.
Well thats the really odd part,
As soon as i took that line and just had it connected to the Boost Sensor Vacum was cack to norm
And Honestly i thought the same thing too
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
if you're connecting that line to the boost sensor then that would suggest you are using manifold pressure for the charcoal cannister, you should be using one of the ports off the throttle body for the cc.
on the 1j i believe it is from a metal bracket which bolts on the side of the manifold, you can follow it from the front to the bracket, to the top of it, crosses to another bracket from memory then to cc
hth
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
Just ditch the CC and route the line to the lefthand under the car, it will improve your emissiontest and clean up the engine bay.
bobiseverywhere
bobb'n for money
Montreal
hth
Looks like you were right :) changed a vac lines around, boost gauge read more accurate now as well lol :):)
