Vaccuum Leaks?
born2drv
1,199
Burbank, CA
Where are the common areas to look for when trying to find a vaccuum leak?
The Accordian hose, the PCV, ISC, and BOV. Anything else?
I only run -10 @ idle, (aftermarket mech. boost gauge) so I know something is wrong, it pulled -19 to -22 before. The only thing i did was replace the PCV system (huge hose, catch can). Could the large hose mean more flow and less vaccuum?
I have it setup so that the N/A pipe for the valve covers brings the hose to the catch can, and from the catch can to the accordian hose. I also blocked off the other port on the throttle body.
