vaccum?
aye mate
Hiatus over.
Maryland
I know that vaccum on the 7M is usually around 20 in.hg. But over the past few months when I start my car up and it is cold I get a reading of 17.5-18, but after she warms up its about 19.5-20.5. I don't have any leaks. Motor has close to 160k on it. I'm also thinking that it might be my boost gauge, its like a 40 dollar AutoMeter. That actually did not read any boost for the first week it was installed, but as I drove and boosted I guess it "broke in". Any thoughts?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I have 163k on mine and it seems very similar to yours with the same meter. Mine worked correctly out of the box though... I can hit -22 *vacuum on deceleration at speeds.
aye mate
Hiatus over.
Maryland
Yea, on decel it reads about 22-23 depending on RPM. I'm really close to buying a Greddy gauge, theres a dealer that is offering them in PSI for 140 on Ebay.
Bishop92t
773
USA
www.ma70.com
The cheaper product lines of Autometer are notoriously inaccurate. If you're worried about engine health do a compression test. Typically vacuum is dependent on engine health, but even a small leak can change the reading you get. There are other factors that come into play though, that's why a compression test or leak down test are a better diagnosis. Mileage isn't too much of a factor on most Toyotas, 7m included. I've seen 7m's with almost 200k miles and perfect compression, it just depends on how well the motor was treated.
edit: and I highly recommend GReddy gauges :) They aren't cheap but worth every penny.
aye mate
Hiatus over.
Maryland
Thank you Bishop, your input is much appreciated. A compression test is in order, I was thinking along the same lines. I have a tester but the end that goes into the plug hole isn't long enough for the gauge to clear the valve covers, I need one with a hose type deal on it.
