Vaccum Hose Reduction? HOW???
turbomk3
Does anyone know what vaccums are necessary? pics would be helpful....who all has done this before? Are there any write ups on this?
thanks guys
Justin
Speakers?
Spokane, Wa
thanks guys
I can take pictures of what I'm going to do but it wont' be for a bit, I can't seem to find a head that isn't warped.
All I'm going to run is FPR, BOV, Heater VSV and Cruise Control. Maybe PS Idle up, we'll see.
also boost gauge/controller
No VSVs, no egr or charcoal canister...
MDCmotorsports
Indy 500
www.MDCmotorsports.com
You only need two vacuum lines:
-One for your BOV and ...
-The other for the Fuel pressure regulator.
Three vacuum lines:
-For your boost gauge inside the car
Four vacuum lines:
-For power steering assist
Five:
-Cruise controll
Thats it....
If you don't plan on running emissions.
If you have to run the emissions, good luck. Refer to a Toyota manual for all the EGR, VSV, and the likes.
Yawgmoth
Gonzo apprentice
Davenport, Iowa, United States
mdc nailed it. If you search for this on supraforums (eeks, sorry I know this is supramania) you can find a post or bishop89t's in which he posts his engine bay and it shows how to do it. or you can just pm through here, I'm sure he'd be glad to help.
I<3Supras
Drft What do u mean drft?
Southern, Ca
Well i don't have a account on SF and i can't make one so can someone post the Picture? i would appreciate it. Thanks
Idealsupra
Orlando
www.tampabaysupras.com
well if you want to use heat you will need a vaccum line to your heater valve as well...
i have 5 hooked up:
fpr
bov
PS idle up
Boost gauge
Boost controller
Justin
Speakers?
Spokane, Wa
could someoe post a pic of bishops engine bay? I'm horriable at finding stuff, but i'll edit this post if I do ever find it over on SF
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Hey Idealsupra, what's that nifty little box all 5 of your lines run into? Is it like a station where they get vaccum sent out from? Where'd you pick it up?
eric
Justin
Speakers?
Spokane, Wa
eric
Since he's not online at the moment: Its a Golden Eagle Vacuum Manifold. they're between 50-60 shipped. Nice unit. Mine should be here anyday, right Ideal? ;)
mkIIIman089
Ohio
That is a pretty sweet unit... I bet it helps a lot for guages, turbo timers, boost controllers etc. Migt have to get one myself...
