vac. port off the manifold
malloynx
NC
i broke the vac port coming out the firewall side of the intake manifold. does anyone know the size of the thread or where i might be able to get a new one?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
just broke the vacuum tube off of the fitting?
ich... um, either go to toyota for it, or i mean... someone has to have extras... if i did, i'd gladly send you one. but i only have one of 'em.....
i think you're stuck with toyota on this one. i often wondered if you could use a brake line fitting and some brake line, but i dont think there's anything behind the threads to hold a bubble flare or whatever kind of flare you would use...
welding wouldnt work, more like brazing ;)
Dirgle
Conjurer of Boost
Pauma Valley, CA
I know this isn't much help, but my boost gauge install kit came with a fitting that was just the right size for it. So it is possiable to find a replacement other than Toyota(though they may still be your best bet). I'm not sure what size it was though, so not much help here sorry.
p5150
ASE and FAA A&P Certified
Central Idaho
Just go to a hardware store and get a brass nipple with 1/8 inch pipe thread. It should go right in and cost about 50 cents
