V Band Flange
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
That is a hugely odd size. Are you sure of the size?? It sounds like you're after a flange to weld onto a pipe. The diameter of the flange end needs to be 4 inches, and the ID of the pipe needs to be 3.25 inches. Is that correct?
If so, just use a regular sized v band to fit the turbo, then a transition pipe to go to 4.
SupraDupra500
195
Terre Haute, Indiana
MDCmotorsports;972449 said:
Sure they do. You didn't call them asking for a complete $190,000 turbo kit now did you?
LOL.. True!
Al, im positive of the size.. i even called a couple different places to make sure i was measuring it correctly. the outermost diameter is 4".. inner or pipe diameter is 3.25".. Theres a machine shop not far from where i live that is going to C&C one for me. so it's all good.
Thanks for the help everyone!
