Well, i wired up the throttle cable last night, but it didnt seem to work the best. It has a bunch of slack in it. Does anyone know what is suggested to smooth out the throttle cable? It was working pretty perfectly on the donor car.
viperkillertt said:Also does anyone have a quick cable for the cruise control?
Bigzavs said:its a 92-96 4cyl throttle cable, im using one and it works great
Freshmaker said:If you want a quick fix... There are ends that they make to go on throttle cables. You just slide the cable through and use a set screw to hold the end in place. Then it would be your perfect length.
I don't know where to buy them though... we usually have some laying around.
