AllanL said:heres the idea..
HOPE it works will try it out in the next weeks unless someone shoots a nice big hole in the idea![]()
cjsupra90 said:actually it might work with a slight change. correct me if i am wrong, but the Wolf unit fires the IG circuits in sequence correct? (IG1, IG2, IG3, start over.) If so then wire it as follows:
IG1 to IGdB and to IGT
IG2 to IGdA and to IGT
IG3 only to IGT
Allan_MA70 said:figgy you give up too easy! it would be nice to use the stock ignitor just to make it easyer to return to stock ecu if ever needed
