Hey guys I recently purchased a very clean 1991 Supra turbo. I have owned Supras in the past but never a 7mgte. It was a grandpa driven car with very regular maint performed.
I am aware the headbolts are under torqued from the factory. However I also recall reading some people "re-torque" their stock bolts in sequence to 72ft lbs to provide better durability under boost. My question is, are the factory bolts torque to yield? Will they stretch and lose their strength if tightened?
Also, what is stock boost pressure? What is safest on a bone stock engine? Could I raise the boost to 8 and be safe?
I just recently replaced a lot of maint items such as plugs, CPS, ignitor, Alternator, TPS, knock sensor, transmission service (a340e) and brakes and tires.
Now that I have the car running healthy I would like any suggestions if possible about what I can do and what should be done. I payed a little over 5k for this beautiful Supra and I feel like I'm walking on egg shells everytime it goes into boost (Even in overdrive :cry: )
Thanks guys!
Thanks guys!
