Using a wideband with a Stinger
5uprahboy
343
Auckland
Hey all,
Can the wideband sensor be hooked up directly to the stinger? Or does the sensor need to go through the wideband "brain" and then into the stinger?
I'm using the W/B sensor that you get with a Zeitronix kit
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Using the 4 wire Bosch sensor you connect it directly to the stinger, and the stinger acts as the wideband controller (no brains needed).
You could also use the Innovative LC-1 for a WBO2 input, but I like keeping things simple.
You won't be able to connect the zeitronix wideband sensor directly to the stinger, I had to sell mine and buy the 4 wire sensor.
RacerXJ220
Interdimensional
Abalama
AEM WB output won't work either from what I gather.
I'm definately going four wire when I get home.
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
Warning: Newb questions coming up.​
So the Stinger takes the place of a wideband too!? That thing does it all. I know I sound like an infomercial, but damn, I get more and more impressed the more I learn about it. So I could buy one of these:
http://cgi.ebay.com/ebaymotors/Toyo...-wire-NEW_W0QQitemZ270120471554QQcmdZViewItem
and be set? Then, all I would need would be the wideband display/gauge to see the numbers?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
no, unfortuntely they use the most expensive (not to mention hard to find)Bosch LSM-11 AKA P/n: 0258-104-002.
Fortuntely driftmotion carries it for us.. it's on their main page.
5uprahboy
343
Auckland
Its just a shame they are so expensive compared to the 5 wire type. The 5 wire are around the $55 mark - bugger...
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Yes it is an expensive sensor, but it is still less then buying a controller and the sensor, like most other brands require.
The Bosch LSM-11 was originally designed for industrial high temperature gas furnaces, it is very durable.
It's not even close to being the most expensive wideband sensor though. Some are well over $300.
From the Stinger Help Files:
Bosch 5 Wire Wide Band (Innovate LC-1)
In this mode the Stinger ECU reads either analog 1 or 2 of the LC-1.
Before the LC-1 can be used with the Stinger it must be calibrated. Use LM Programmer
software to calibrate the LC-1.
Set the output to read 0.050 volts for 8.0 air-fuel-ratio and 0.950 volts for 22 air-fuel-ratio.
5uprahboy
343
Auckland
I've been told the LSM-11 isn't a "true wideband". Is this true?
I would like one, but I dont think I'd really have a use for it. The only reason I'd use it would be just to say "hehe look at my fuel". I wouldn't use it for tuning.
5uprahboy
343
Auckland
bigaaron said:
It just doesn't have quite the range that some newer sensors do, but that doesn't mean it's not usefull.
Ok thanks. I'll look into getting one at a later stage. Right now I just want to get it going, again.
How annoying, a few months off the road getting the stinger working, then as I get it running, I pull it off the road to put in a bigger turbo hahaha
