used turbo ???
gsxr141
1,158
10
rochester
hey all. i finally got my fresh motor in and put some miles on it. before it blew i had some smoking on decel, and i thought it was something in the motor. well, it's still doing it a bit, so i'm thinking it's the turbo now. i have a spare stock turbo that i can throw on, and i was wondering if there's any way to tell if it's good before i put it on.
thanks.........
BryanDyer
654
Georgia
thanks.........
Before jumping straight to conclusion, did you do any tests to cancel out any other possible causes? Like a compression and leak down test? Check shaft play, check piping for oil, check downpipe for oil.
What exactly do you mean when you say "fresh"?
gsxr141
1,158
10
rochester
there was always a little oil in the intake side of the pipe. the motor that's in it now is fresh, but i didn't do a compression or leakdown test.
Backlash2032
1,823
Nebraska
Fwiw, I will never put a used turbo on a car ever again. I've gone through 3. One of which was "freshly rebuilt" Its just not worth it.
Sent from my HTC6435LVW using Tapatalk
