Suprasport makes drop in 550cc injectors without having to change the stock clips or cut the harness. Heres the link: http://www.suprasport.com/SupraSport-Custom-Injectors_p_5466.htmlthevork;1412170 said:AFAIK MK3 supras never came with 550cc injectors.
Also, I don't know of 'drop in' injectors for the 7M. All injectors need some kind of modification to make them fit the stock clips. (or you can replace the clips)
Top feed injectors WILL fit your fuel rail however.
550cc Nippondenso injectors will most likely be Mazda RX-7 Injectors. Be sure to get the right type.
1988ma70supra;1412260 said:Suprasport makes drop in 550cc injectors without having to change the stock clips or cut the harness. Heres the link: http://www.suprasport.com/SupraSport-Custom-Injectors_p_5466.html
