I found out yesterday that my stock oil cooler is cracked and bent beyond repair. It happened at my friends shop where I have a little project going on. Anyways, I am not ready to do a full Oil system upgrade yet, but I was wondering If I can just get a better Oil cooler like the B&M Supercooler 70266 for now and just connect it to the stock oil lines, meaning just replacing the broken cooler with a B&M one. I will off course follow thru with the NA block adapter, Thermostat etc probably later in the summer. Will the only difference be just adding a little more oil due to bigger Cooler? I searched but havent ran into that actual question. I'll go back to continue searching now.
Thanks
Thanks
