ok well the time has come and i am doing the na> t swap.
Now i only have a couple of questions.
First if i have tht ecu and wiring harness from the turbo model, would i be able to just swap out the ecu's, or will i have to still rewire??
(i only ask because many people keep their stock ecu and just re wire it to the point where it needs to be re wired to be able to work.)
secondly, i know the tach wont work from an na does any one know how to fix it, or can i just simply use an after market??
thirdly, is there a lot of rewiring involved if i do the ecu swap mainly im asking in acc. wise, such as power steering and charcoal canister etc.? will it be a basic motor swap or will everything have to be changed!
lastly, i would like to thank all, i also the fact that you guys gave me that link to that site is extremely helpful i learned alot.
