unknown leak
626na
143
cali
hey i just changed my heater core hose and and everything was fine until i saw some coolant leaking underneath the shifter....?
what can this be.it also drips on the exhaust and it starts smoking a bit
626na
143
cali
the carpets are good. i cant lift the car right now because i have no jack at the time, its right next to the shifter but its coolant
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Did you change the hose on the drivers side or the one of the passenger side. Every 7m motor I've worked on has bad corrosion and/or rust around the spout on the back of the head where those hoses go. Sounds like it's leaking around there and is following gravity and traveling down your transmission, which runs very close to the exhaust and shifter. Is it a bad leak?
cuel
1,536
Baytown, Texas
You need to borrow a pressure tester and find the leak so you can fix it. Little leaks have a habit of turning into big bad leaks at the worst possible time.
supraman508
496
maryland
I had this problem it was the hose that is in the back of the engine on top of your e.g.r cooler.check that hose for leeks.for some reason the drip travled all the way down to the side of the transmission.
