Unknown dash warning light came on today! what is it?
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
As I was driving my car a new warning dash light came on today(new to me). Its a little car that looks like its flashing the rear lights. Its right on top of where the ABS warning light is. Anyone know what this is?
After i turned off the car, it went away. But then after i got home, It turned on again.
Supra-Man18
357
miami
Its probably a loose contact In your tail or brake lights.. Or it could be a bulb with some corrosion causing bad contact... go over the bulbs first then the wires..
gaboonviper85
3,236
Northeast Philly
It could be your brake lights, light on the wing or rear window, rear quarter panel blinker lights, lisence plate light...your brake lights may still work but are they equal brightness?
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
They all seem to be working, Ill take a better look at them tomorrow. Thanks guys!
tissimo
Stock is boring :(
Melbourne, FL
If they're all working and the light is still on, the sensor box is the problem. The solder joints iirc go bad on them. There are threads on how to go about fixing, it just search for it.
DeanRam23
4
Maywood
What about if you have an 88 N/A Supra, and you switched to the 89+3 piece wing and tailights and you're having the same problem?? Buuuuut only the light from the wing doesnt turn on when hitting the brakes. Like if it aint connected but it actually is! What can it be??
