Understanding on fuel cut
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
Ok so I have a greddy profec b spec boost controller and an apexi afc neo, so I have all the adding fuel to the mix covered, how can I raise boost cut, I'm hittin it at about 14 psi on a 57 trim.
I'm not looking for astronomically high boost just a Lil more than I've got now, any ideas?
gaboonviper85
3,236
Northeast Philly
you are maxing out the lex afm...good friend of mine is hitting fuel cut with his 57 upgraded ct at 15 psi so yours sounds about right. youll have to finally change to a standalone or maftpro type setup using speed density
jdub
Feb 10, 2006
10,730
Valley of the Sun
Even with a Lex, you will max out at 16-18 psi of boost depending on OAT, the IC piping, type turbo, and DP used (plus a couple other factors). Keep in mind FC is determined by the volume of air that flows past the AFM, not the psi produced by the turbo. As a result, every car is going to be different - even those with the exact same turbo configuration.
giterboosted
Nov 3, 2007
597
toccoa ga
Well I have a maft base model tho, never coul get it to work rite, maybe now that I have a better understanding of my engine (that was about a yer and a half ago) I'll have better luck, will my afc neo still work the same with a maft?
giterboosted
Nov 3, 2007
597
toccoa ga
Nobody? It's a base model low as you go maft, just a box with some wires to a gm maf, all I wana know is will my neo still be effective
ohiosupramst
138
Cincinnati
You no longer need the neo hooked up at all. The maft pro is a piggyback just like the neo but it uses a speed density sensor which is better than a maf.
Kckazdude
1,239
Memphis, TN
You will still need a way to tune with a MAF-T. All the MAF-T does is convert the signal from the larger GM MAF sensor into a signal the TCCS recognizes.
giterboosted
Nov 3, 2007
597
toccoa ga
Thank you!!! I tried to tell ppl it's NOT maft pro it's just plain old maft, nothing special about it, ao yes it will be just fine to run the neo with the maft
grimreaper
2,180
Dallas
keep the neo to fine tune the maft-t. And speed density is not better then a MAF. Whats the 40% insulation tid bit ?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
The Base MAFT does allow some tuning, its just not very great. If you dont want speed density then go MAFT GEN2. It alows greater tunability without the need of a SAFC of any type.
If you want to raise fuel cut without going standalone run 50psi base fuel pressure and pull crazy amounts of fuel. This will raise fuel cut but also cause a more advanced timing curve. Gotta pay to play.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
First thing what is your setup and second do you have a wideband? Are you adding fuel with the NEO? If you are adding fuel what is your base fuel pressure when the car is warmed up to operating temps?
Once you know those little but important things you can start to play with your air/fuel ratio....
1) Adjust fuel pressure to so that the car idles well (dont worry about the a/f ratio #’s at idle to much)
2) Drive the car and watch the you a/f ratio while driving normal (normal driving should stay between 14 and 15 a/f)
3) Do a quick pull and watch your a/f ratio when flooring it (or wide open throttle WOT for short)
4) Once you have an idea of what your car is doing then make some changes. If you are running 550’s and the Lex AFM you should be around 10-10.5(a/f) with the stock tune, but that will change according to your specific setup. Typically bumping up the fuel pressure and scaling back using a piggy back with get up fuel cut up in the 20’s (in terms of psi).
