Finally took the 88 turbo on a good long run....after being parked for a while i noticed a drip of gas at the right frame rail behind the wheel a bit.Low and behold i notice a loose steel line that attaches to a hose on the bottom of the cannister with fuel weepin out!Wtf...never noticed it before...put the line into a grommet at the subframe just because thats where it looked like it was before...running great...drove home...Is there too much psi from the 255 walbro...is the return blocked?...did i reverse something when i redid fuel ,vent , and return lines?...have a pic of the line on my phone to upload soon...going to check fsm....back in a bit!
