What is the oil pressure supposed to be at during various boost levels?
My engine is running fine now (need to fix the knock sensor wiring still...) but I just wanted to make sure the pressure levels are ok. I have a small turbo oil leak (replacing in a month or so w/ an upgraded ct26) but nothing else is leaking (unless it's invisible).
I tried searching, but the terms "OIL" and "PRESSURE" come up too often w/o any good insight.
Thanks,
Jeff
Thanks,
Jeff
