uh oh!!!
MKIIINA
Destroyer of Turbos
Plano, TX
Disced said:
Looks like the one I have...
Hope you didn't pay more than $180 shipped.
dont be a dick....
nice grab man! no go get your pipes finished and then report on how much you like it!
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Start a build thread and consolodate all these threads man...
BTW: Nice IC... I have the same one... Did you trim the hood latch bracket much? ;)
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
ICE, you will have to trim your latch brace, or remove it, BUT, if you remove it, then shutting your hood becomes trickery...
Tek: its an XSpower, bar & plate, internally finned... Its actually a REALLY nice piece... I have the same one...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Tek here it is with a Dr P can as a reference to its massive size, and also a pic of it mocked up in my car...
gixxer750
2jzget comingsoon!
Mississippi
Well, actually on the hood latch brace thing.... I built mounts for the lower part of the intercooler, and tried to figure out the upper part.
I ended up running 90 degree angle aluminum stock all the way to both headlight braces. I cut one side of the 90 off, folded the other side over to make a flat end on it. drilled a hole in each end, and put some sheet metal screws through the headlight bucket supports. Then I drilled a hole in the middle to bolt the hood latch to for supporting the hood latch.
