ugh, Fog Lights STILL don't work
johnathan1
Supra =
Aug 19, 2005
5,056
ok, so my fogs haven't worked since i've had my car, I have replaced the actual housings, and they are known good, and new bulbs, hooked them up, and they don't turn on, also replaced the fog switch w/a known good one, and replaced the fuse. What could be the problem?:1zhelp: , UGH!
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
relay? wiring? bad grounding?
I'm sure a more elecronic-savvy person here could chime in...but if you need anything I've probably got a spare.
johnathan1
Supra =
Aug 19, 2005
5,056
hmm, i was thinking that it could be the relay, but i've listened carefully, and I'm pretty sure that I can hear the relay click on... As for the wiring, i can't see why something would be wrong with it, I took of the undercovers, and all wiring going to the fogs is intact, in fact there were cobwebs in there, so I don't think anyone has been tampering w/ them... grounding...hmm... were are they grouned at? anyone??
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
johnathan1 said:
okay, i've got to be the dumbest Supra owner ever, there was no fuse for the fogs... They work perfectly now, thanks for everyone's time!!
:wtf:
sorry...had to. Good job on making them work again, wish mine were that easy to fix, the housings on mine were so rusted out there was nothing left for the ground wire to connect to!
