Ugh, Cam gear swap
Justin
Speakers?
Spokane, Wa
I got some new to me cam gears to replace my bent ones... Is the replacement simply going to be pulling off the cover, pulling out the plug for the bolt on the tensioner and letting the bolt out a bit? sliding the belt off the gears, putting the new ones on, and then be done?
Just wanna kinda get an idea of what I'm in for :)
_ justin
Justin
Speakers?
Spokane, Wa
thevork said:
Are they ajustable maybe?
If so, cut the upper timebelt cover while you have it off.
Otherwise you'll find yourself removing and reinstalling the thermostat housing at every change. ;)
They're adjustable. I have the ATI clear cover that is already in two parts :)
