figgie said:
u joint bad??
On a supra??
no way these u-joints in the ds are not some paulty piece. I have yet to see one fail i have seen a ton of cars with other shit broken to include broken drive shafts but no broke u-joints.
They do go bad. We had one car come in the shop with 2 bad ones, and the drive shaft had already been replaced 3 years earlier with one from the boneyard.
There aren't any grease fittings, so eventually they dry out.
Last week an '86 nissan truck came in with an engine dying problem, but the ujoints and center support bearing were shot. We had to get that fixed before we could drive it. I dropped the 2 piece shaft (like our cars) off at the driveshaft repair shop. $304, with my discount.
It was so bad they had to cut off the end and weld a new piece on so they could install a new joint. Then they had to balance everything ($65).
Sooo....if you hear a noise, or happen to be under the car for some other reason, check those joints, and replace before they cost you a whole bunch more.:icon_surp
