Well.. winter is holding off, so my upgrades are put on hold until the snow hits, but I have some problems with my 88 Supra, and wonder if anyone can clue me in to what I should be looking at.
First... the car is damn hard to shift into second gear, or out of second and back into first... third and fourth are fine. Is this a fluid issue?
Second, the "rad" light on the right side of my dash comes on when I start the car up now, but goes off as soon as I take a corner. No heat issues (if you trust the stock water temp gauge) that I can see, but when the last mechanic touched my car, he left off the vacuum hose that comes from the top of the waterpump elbow. Dont know if this would have screwed anything up because I drove with it off for about 3 weeks before I noticed it. Not even sure if that is a Rad light.. its just shaped like one.
Third (final), my lower ball joints are being replaced in a couple weeks (when they arrive) and I was doing some small swerving to see how bad they felt (doing an "S" drive down my street) when I noticed that if I turn sharp, it "thunks". You can see the hood vibrate when that happens. Will the lower ball joint just do that? (non-7mGTE related question.. but relavant to a MKIII.)
Just asking the gods here to bless me with wisdom so I dont end up repairing the wrong thing. Just a note regarding the rad, I do have one sourced (a larger rad) just because I have been told that one of the main issues with BHG on 7MGTE's is the heat on the back pistons (the rad is insufficient). Going to be hard piping the intercooler at the same time as I upgrade that.
Any helpful info?
Thanks!
Any helpful info?
Thanks!
