twincams battle build
strictlySupra
157
Canada
well i found my build thread. :biglaugh: but it is more than 766 days old haha so here is a new one
couple years later..
so much has changed in the car since i started modding it. and the path has also changed quite a few times.
with the car nearing its completion i figure id share the build with everyone
i guess ill start off with the typical parts list and car description so here goes
the car:
1986 jdm ma70. the car had 160 000 original kms on the body and i was told around 80000 on the tired 7m. now the original plan was to keep the 7m and focus mainly on chassis mods and build the engine at a later date. I soon scrapped that idea and decided to jump up to a jz platform for obvious reasons.
the car was unmodded when i bought it and then it sat untouched in my garage for close to a year.
mod list:
exterior -
6000k hids
jza70 R mouldings
91 + mirrors
gRacer front with OEM turbo a duct
kaminari sides
kaminari rear
S2 Project front wide fenders
S2 rear blister fenders
Vis carbon hood sprayed white to match paint
carbon GT wing
interior -
FULLY stripped interior ( no dash, no heater, no anything)
6 point custom welded in rollcage
2 Sparco pro2000 seats
2 takata harnesses with shoulderpads and 5 point conversion
nrg quick release
Sparco monza wheel in blue suede to match the seats
battery relotcated to behind driver seat in custom box
full defi gauge setup (fuel press, oil temp, oil press, water temp, boost, egt.)
defi 11k tach
defi link display
engine -
2jzgte stock twins
wire tucked (igniter fusebox and all wiring moved to dash area)
greddy intake mani
q45 tb w/greddy tps adaptor
greddy pulley kit
greddy timing belt
Blitz front mount kit for jza70
koyo rad
fal fans w/shroud
hks ssqv
optima red top battery
samco rad hoses
RCI aluminum 10 gal fuel cell recessed in spare tire area
aeromotive a1000 pump
aeromotive fuel filter and fpr
-8 stainless braided fuel line feed
-6 return
drivetrain -
r154
rps carbon/carbon
driveshaft shop 1pc steel driveshaft
cusco 1.5way type rs lsd
3.73:1 gears
suspension -
the cage
cusco front tower bar
megan track series coilover
suspension techniques sway bars front and rear
a1 rear toe and camber kit
jic front upper control arms and lower tie bar
GP sports super angle kit (thanks garagefujimoto)
BIC swaybar endlinks
Work Equip 18x10 fronts and 18x12 rears
most likely a few other things that i have forgotten also.
thanks for looking ill be adding pics as i sort them all out
strictlySupra
157
Canada
heres a virgin shot
getting things underway, seems like forever ago
cage beginnings
can see the battery relocation here
fuel cell setup , ive since upgraded to an aluminum unit because it looks alot nicer and has a sending unit for a gauge.
a nice shot of the equips right after being refinished
neat and tidy engine bay
ABS no more
getting the 2j nestled in
blitz fmic
strictlySupra
157
Canada
tight fit
fuel system progress
doesnt get much deeper than this ;)
rear suspension components
running
on the home stretch
S2, you can probably imagine how happy i was when this stuff arrived
and that pretty much brings you up to date. im also open to any criticism haha
thanks for looking
staticpage
Banned: Scammer, liar, cheat and thief
Oct 3, 2007
310
Cincinnati
that rps carbon/carbon is one sweet mother, have you used it yet? I have been shopping for a twin disk let us know how it feels. rest of the build looks great to, like the white.
strictlySupra
157
Canada
thanks for the good feedback!
drewsh666:
the works are -7 in the back
those white wheels are Kranze Shoki's and the rears are -27 haha. unfortunately they dont fit, even with the widebody. im sure i could make it work with more camber, but im happy with equips for now
staticpage:
the rps carbon/carbon is an awesome clutch. SOOO smooth, yet the pedal feel is still kind of aggressive which i like. and they have a new design which apparently stops the flywheel from grenading which is good. i broke it in last year and drove it a bit before my slave went.
true story actually i have the first rps carbon/carbon for the 1jz. i ordered the clutch from rps and explained to the guys that i have a 2jz and an r154 and he assured me that he can make it work. so they changed the spline on the discs to that of a r154 but left me the getrag pressure plate. needless to say the pressure plate had clearance issues in the r154 so i told rps of my dilema.
they replied and ask me for the correct measurements so i would have no clearance problems and told me that they were going to make me a clutch from scratch specifically for my application. i thought that was pretty cool of them
so ya. i got the first one :p and i wouldnt hesitate to deal with rps in the future
strictlySupra
157
Canada
UPDATE!
the exterior is finished exept for a couple minor things. i also cracked the front bumper on the first drive which is kind of dissapointing. shit happens.
i still need to get some seat rails and a steering wheel hub so i can instal those things. ive got the defis in though pics soon!
also i know the side mirrors need to be black thanks lol.
thanks for looking
strictlySupra
157
Canada
Mk3runner;1306584 said:
What's your goals with this setup
i want to drift. i built it to drift. although i wont be competing in the local series due to a few deficiencies in the roll cage. So this year will be mainly practice and focus on learning the car really well. then go full out next year, if anything im sure it will be a good show.
